What engine size and hp range are you at? What exhaust size,converter stall,and gear ratio are you running? What headers are you running now?
My motor is a 440, soon to be rebuilt. The car is a 4-speed with 3.23 rear. I'm not sure what to do to the motor yet, but he's what I think it has now: 30 over, stage IV heads, lunatti cam, holley 750 dp and arias pistons. I'm looking to run on pump gas and the car won't see the track. I'm trying to keep my budget down and I'm looking for suggestions. My exhaust is currently 2.5, but I plan to upgrade to 3 in the future. Thanks, Jim
check out the hedman elites. thick flanges, heavy wall tubes, ceramic coated for less than $400. IIRC they don't go under the steering, either. they're only 1 3/4", which is fine for a mildish street BB. for heads, do you mean stage VI's? for the money, you'd be better off going with edelbrocks
1976 Spinnaker White Plymouth Duster, /6 A833OD 1986 Silver/Twilight Blue Chrysler 5th Ave HotRod **SOLD!*** 2011 Toxic Orange Dodge Charger R/T 2017 Grand Cherokee Overland 2014 Jeep Cherokee Latitude (holy crap, my daughter is driving)
