Originally Posted By justinp61
Where does the oil return from the cam/lifter area?
It returns the front bay through a drilled hole that goes to the timing chain area and the other bays by a hole in the rear that returns to the oil pan area. What I mean by bays is the cam bearing saddles kind of create a bay in between each cam bearing saddle.
#2 through #5 have a channel that directs flow to the rear.
I'll try and take a picture this weekend.
