Also, They do not fit very well in an A-body. You can see how I had to mount it with the motor inside the door and the track on a pretty bad bind. Still doesn't work when I straighten the track out like I said earlier.
The only way to mount it straight would be to put it right where that big brace is inside the door, so that won't work.
1970 Challenger, all aluminum 528 Hemi, HDK suspension, Tremec 5 speed manual
