Re: 360, A/C, Weiand intake,Comp bolt hitting thermostat housing
[Re: grancuda]
#2450715
02/12/18 04:07 PM
02/12/18 04:07 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
This is all good information. I assume grancuda would like to keep as many parts as possible that he already has.
The options I see are: 1. cut the nut a little like 4406bbl mentions. 2. replace the compressor bolt with an allen head (rounded/flat head) & run it the other direction through the compressor so the nut is on the other side. This may make some compressor seals leak? 3. find a thinner thermostat housing... I do think the stock ones (at least on big blocks) are "stepped" in that area. I like this idea best if it's possible. 4. Grind a little clearance off the thermostat housing.
For the heater hose outlet....can you find a 45-degree outlet & use a bunch of Teflon tape so that when it's tight, it points away from the compressor? You might have to try a few times to get the right amount of Teflon tape OR maybe use some "reactive Teflon paste" so it will still seal even if it isn't 100% tightened?
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
Entire Thread
grancuda
02/11/18 06:11 PM
grancuda
02/11/18 06:13 PM
mopars4ever
02/11/18 06:31 PM
Supercuda
02/11/18 06:45 PM
340Cuda
02/11/18 06:44 PM
4406bbl
02/11/18 08:53 PM
Guitar Jones
02/12/18 06:17 AM
Porter67
02/12/18 08:52 AM
Supercuda
02/12/18 04:13 PM
Eggman
02/12/18 01:29 PM
PurpleBeeper
02/12/18 08:07 PM
mopars4ever
02/14/18 02:02 AM
