I have 2. Frame is fabbed fro 1" steel angle. Inner and front bolts go through the outer frame flange. Outer bolts are plated under the floor. 6 bolts hold the battery frame work. Bottom is spaced up with 1/2" tubing for the mounting bolts to keep it level. Fuel pump mount is integral as well. Doug
