"What brand cam company makes a three bolt cam for any Mopar V8 with 3/8x24 (fine)threads per inch?
All the three bolt cams I have seen or used, race or stock, all had the course 3/8 bolt holes in them
Are you using the Diamond brand 3 bolt roller thrust bearing that Hughes and Mancini sell?
Mine came with the proper size and thread bolts to work correctly "
Cab this is a Comp cam. It looked a little different than the one it was replacing(lifter failure) including having a much shorter pin, so I called them and sent it back to have a longer pin installed. They said it was a different core(actually a better one they said) but would work . They said it was my responsibility to find bolts that fit.
I can send you photo's of both cams showing how they differ if you send me your e-mail
Thanks Mike
Yes a Mancini roller button.
Mike
