What brand cam company makes a three bolt cam for any Moopar V8 with 3/8x24 (fine)threads per inch? confused
All the three bolt cams I have seen or used, race or stock, all had the course 3/8 bolt holes in them work
Are you using the Diamond brand 3 bolt roller thrust bearing that Hughes and Mancini sell?
Mine came with the proper size and thread bolts to work correctly shruggy
