It’s worth decent money to someone that can use it.
The problem is, each brand of tooling kinda needs their own stuff for compatibility.
Snap-on more than likely had that made by another manufacturer.
What diameter is the pilot?
Each brand has their own size, so the size of that pilot would give you an idea of what it’s compatible with(Sioux, kwik-way, black and decker, etc).
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
