Originally Posted By humpty
- Airbox
- Dominator
- Vacuum pump
- If you’re ambitious gapless top rings
It already has an air pan that is sealed to the hood, low tension but not gapless rings. When it's time to rebuild if Brett will work on my manifold I'll see about going to a Dominator. It currently has a BX4 main body that is supposed to flow around 1050.
