Get stiff-wall slicks.............Problem solved.........
[/quote
I have a par of 28 x 10.5S, but you can't run them in a street car shoot out type stuff.
Okay I'll move the battery. From what I've read if I move the battery the car has to have a master power kill? Which switch? Also the best way to wire it? It looks like some guys use a ford solenoid in the trunk so the main power wire to the front isn't hot unless the engine is cranking. With the Moroso box I won't need a bulkhead behind the rear seat so that looks like the simplest rout to go.
Gotcha...........
