The issue is not the carb. It is the availible fuel. Today's fuel evaporates quick. Add an electric pump, problem solved. I don't believe anyone has had a fire in the float bowl. There would be significant damage. When I has this explosion it melted the accelerator pumps. Did nothing to the rest of the carbs.
Doug
