Originally Posted By ns1aar
On mine it was going thru the hole on the driver side where the rubber flapper valve is that opens and closes with the accelerator pump
I don't see how the flame could go in from the top. This has to be in a power valve type of circuit. Maybe up through the jet, around the power rod when it is lifted up. It then flashes when there is very little fuel in the bowl and goes back out.
