I have m/t slicks on stock rims, you will need to drill out valve stem. With a 4 sp run a stiff sidewall slick and skip the tubes. M/T are notoriously for leaking air thru sidewalks, so prep them to prevent air leakage. Usually dawn soap on the inside.
