doesn't Andy's brackets have wiring instructions. run the alt output to the post on the starter relay and then to the battery. run a reference 12v source to the alt plug and maybe a switched 12v wire too... it's pretty simple, wired this way the ammeter won't be accurate. so maybe run an aftermarket voltmeter in the car...
