IF you read this post from the beginning you will see that I did fix the exhaust. That was not the problem. A tech said he thinks its the flex plate. I'm looking for thoughts on this... As in are these flex plates know to crack? How Can I know for sure with out pulling back the trans? This truck only has 80,000 miles.
