Originally Posted By AndyF
Depends on which rods you use. If you use a 2.200 rod journal and a high quality rod like an Oliver then you might not need to clearance much at all.
iagree scope
With the steel H beam BB Chevy type rod it ain't much, .060 to maybe .120 on a slope up high on the boss sawzall
