Yes, but only if you buy the correct throttle body. They sell a few different ones and it is a little hard to figure out from the description.
The throttle body that I have has TPS, IAC and MAT sensors built in and it has multiple vacuum ports for PCV, MAP, vacuum gauge and ported vacuum for a distributor.
