Originally Posted By Dragula
Nothing like trying to inhale thru a tiny straw with a dual plane intake and small carb...
Even with a mild cam, I would be running a 950 carb on an open plenum intake. That will double the air flow the engine gets right there.
Shorten the timing curve to get as much initial timing as possible with a quick advance.
Right after I'm verifying 0 deck and milling the heads to 79 cc.
