Cant help you on the reservoir but the actual pump itself, saginaw's are nothing to take apart and put back together, extremely DIY capable. They are nothing but a handful of O-rings, one seal for the shaft and if you decide to replace it the shaft bushing does require a press or large bench vise and assorted sockets to press the old one out and press the new one in.
