Thanks everyone for the help not ignoring just busy and not working on the car much as Christmas is here. Here is what I know all lights work on the car
other than the dash lights and dome light. Upon looking at the fuse block I see a violet wire cumming out the the fuse block on one end the of the fuse and the other I see a dark blue with white tracer small gauge wire coming out. Here is a question can it just be the dimmer switch? Or is it the headlight switch. Or should I replace both? Thanks
