The "put a wrench on it and whack it with a hammer" (in the correct direction!) has usually worked for me. Except with a Durango. For some reason locktite was applied to to the threads. After all else failed I fabricated a holding tool with pins. That did it. No locktight on re-install. Kinda like the factory tool?
