Originally Posted By ric3xrt
What's the build?
That spot that you have circled , only has coolant pressure to deal with .I my self am crazy enough to JB weld the broken piece re tap it and roll the dice.....If it were an engine I was building for someone else, I wouldn't take the chance.
Agreed, I'd try to make something work there. Just make sure it's flat without messing up any other sealing surfaces. The M8[?] bolt torque there is fairly low.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
