Originally Posted By Plymouth340
[quote=6bblFLASH]I have an Innovate LC-2.
Works fine,however in a true race application I would think you`d need a playback or record it with a Go-Pro or something. twocents Things happens too fast to be watching on a run. I play on the street and look at it in high gear at the track. scope [/quote
yes. I would think looking at it in high gear would be a pretty good indicator of what's going on. Because once you get it jetted correctly you should be good to go.
What he is trying to say is.. on a race car running
on top end you dont get anytime to be watching a
meter.. you need a recorder to the watching for you
so look into one that will record
wave
