1967-1976 A-Body (Duster, etc)
Metco's one-piece driveshaft safety loop is custom-designed to fit the floor pan of the 1967-1976 MoPar A-Body. The ring is made from seamless DOM steel in an oversize dimension to accommodate lowered vehicles and aftermarket driveshafts. The flanges are laser-cut from heavy-duty steel and the assembly is precision-welded in a fixture. The finished loop is powdercoated black and packaged with installation instructions and Grade 8 hardware.
This driveshaft loop is designed to mount to the floor pan within six inches of the front universal joint, with the loop oriented up in the transmission tunnel. Installation requires that the user add four holes to the floor pan for the provided mounting bolts. Installation instructions are included.
http://www.metcomotorsports.com/proddetail.asp?prod=MDL1600
