They don't care if it has tags or not. Rules are determined by ET, MPH, construction, power adders, and intended class. If it doesn't fit a specific class (Super Stock, Pro Mod, Super Gas, etc.) then applicable rules should be able to be found in the E.T. and General Regulations sections.
If the results don't match the theory, change the theory.
