So here's the deal. LA 360. Been sitting for a few years.
Clean out the fuel system.
Change plugs.
Change oil n filter
Check for spark - no spark. Jump ballast resistor - we have spark.
Fire up engine - have a loud lifter tick from the front left
Shut engine down pull valve cover - exhaust rocker super loose - hyd cam
Figure the exhaust valve was open during dormancy and the lifter is collapsed
pull intake and rocker gear and find the lifter is super dished
So- any idea why it happened ????
Cam lobe looks ok. But I'm hesitant to throw a lifter at it.
