You should be able to remove the balloon seal and the clip and slide them back. Might take a little jacking on the lower control arm. Very slight to get it to line up. I changed the torsion bars on my Dart and seems like someone had an oil filter wrench type tool for grabbing the thing and then hammering. Fasten the tool towards the rear X member so you can swing at it. I forget now... Anyone?
