We will be by your booth at PRI to check this out.
Is the .90 stuff incentives for 4 speed only (as stated) or any number of forward gears so long as it is shifted manually and leaves with a clutch?
All manuals are welcomed under the same umbrella. Just wanted to eliminate the clutchless dudes. Must engage the gears and clutch manually each gear. To be fair, the higher number the gears the price should go up. If you were doing it on the tree.....hot damn, you might need a U-Haul for the payout, thats the most work and toughest time I can think of! I can't afford much more than the $10K proposed at this point or it would. We will see where it evolves. If no one wins, it will most likely roll over to another bounty in another time, place or dimension!
Your thoughts?
