With so many choices out there I am not sure what direction to go on new heads. My combo
Low deck 511
12:1ish compression
Right now I have a 274@050 solid lifter with 590 lift and 108. That may change to a roller.
I don’t necessarily want to maximize the combo but I want the best bang for the buck within reason. My thoughts are ez-1, trick flow 270, or a victor max wedge. I’m not afraid to try some of my own porting.
Car is 2800lbs valiant
727 haven’t chose converter
8 3/4 with 4.56 temporarily
31x13.5 slick.
I see the trick flows are down a bit on flow from ported ez or ported victors.
But would they give up a lot to those in horsepower?
