if nothing appears bent/out of place/not working/wrong parts you might pull the drum & have a helper work the pedal BARELY so the shoes expand a slight bit then let off & repeat & see if the star wheel starts expanding the shoes. work with him so he goes just far enough for the tang to catch the next tooth. Holler what it ends up being.
Keyword here is BARELY, unless you want brake cylinder pistons all over your shop...
