Are there any modern off the shelf options? I got a deal on a lightly used blueprint engines 408LA stroker that has a magnum head conversion. Current cam is the old style .238@.050 .474 purple shaft. All I am finding is dual pattern cams which I don't need with magnum heads and headers.
Entire Thread
Subject
Posted By
Posted
Small block single pattern hydraulic flat tappet cams
