Try the proforged bushing with greaseable pins with zerks.
The bushings come with sleeves and there are slots to spread the grease to make sure its lubed and freed up. Try adding a small slot laterally on the poly bushing to match up with the grease hole on the pin. That will spread the grease better.
Sprerical strut rods will free up a lot of movement too.
Proforged:
