I noticed the rear seal I received from Fel Pro Does not contain the white side seals that would swell up but some blue rubber seals. It also contained 2 bolt spacer sleeves. I liked the way the old seals worked and never had a problem with them.
There are no instructions with the new seals as to where these sleeves go. Bottom of retainer near seal or top of retainer under bolt head?
Are these spacer sleeves required? seams to me they won't allow seal retainer to center seal on crank?
Any thoughts and comments are welcome, Jeff
