2 headlight system uses larger diameter bulbs, so they won't fit the buckets. Guess you could swap buckets, but you would have to also do a lot of mods/custom fabrication to the headlight bezels too. I wouldn't do it...Plus there are the wiring mods.
When you work on Spaceships for a living, how bad can a workday be?
