No, its not. Maybe he wants to run a taller gear in the back. If he wants to get to the 10:1 ratio, a 2.74 only needs a little more than a 3.55 gear where as a 2.45 needs a 4.10.
Yes, you can buy the gear set for a 46RH to get you the taller first gear, but it is quite expensive.
