I would either have everything rebalanced, or keep the engine as it was running before, but make sure you use the same convertor as well.
(Factory) stall convertors came either balanced from the factory, or neutral balanced.
Steel cranks got neutral convertors, cast cranks got balanced convertors to go with the rest of the engine balance.
