Originally Posted By JAKE68
The problem with the strange shock is you can not adjust it tight enough to control the cal tracs. even though they are both single adjustable the valving on the rancho is better
Because it's repurposing a 4x4 TRUCK shock. I'm another one with the old 5-way Ranchos and they work Ok, but I'd like to try a DA shock.
