Originally Posted By cnxt
I thought about trying to hide the diode, ibut the diode was pretty big and didn't see a clean way to make a channel on the solid ballast.
if using a single ballast, would a duel [four pin] ballast work using the unneeded section [after removing that section's guts] as a place to hide the diode ?
beer
