Originally Posted By AndyF
My pump gas 470 makes over 700 hp running unleaded premium. That is why I suggested he switch to the TF heads. The Wilson ported intake that I used on my 470 is for sale in the race section so all a guy needs to do is build a 470 short block with flat top pistons then buy 240 heads from Summit and add the intake that I have for sale. That will give you 700 hp which should run low 10's or high 9's depending on how well the car is set up.
If its making a " track proven" 700, a 3200 pound car will run well down in the 9's easily.
My old w5 motor " made" 708 on a dyno and backed that up running low 9.60's at 140 in good air on 002/003 leafs and cheap shocks. So nothing trick about the car setup at all.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight
418 BPE factory replacement headed stroker, 565 lift solid cam
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
