The instructions says to modify the rod for the adapter to go to the tranny.
If I am reading this correctly, the rod does not hook to the trans. The adapter does. Maybe you should give TTI a call, they were cool guys at the Van Nuys show. May be worth a try? I didn't know they made an adapter. I would have used it! I had to buy a $350 dollar cable shifter.
