Re: BB 727 rebuild kits?
[Re: 440Jim]
#238682
02/28/09 06:04 PM
02/28/09 06:04 PM
Posts: 30,460 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
I buy the parts I want individually, but CRT is your one stop shopping center to make it easy and be sure of quality parts and advice.
What you need depends on your application, but these are some of the things I like to see in a race 727:
- babbit front bushing (converter)
- Bushing kit for the rest (need drivers to install)
- New thrust washers (3 or 4 tab depending on planetaries, or even 5)
- Teflon reaction support rings (for high pressure valve bodies)
- Stock type rear clutch frictions and steels
- High quality front frictions with oil grooves (Alto Red Eagle, Raybestos HD, High Energy)
- Heavy duty rear servo retainer (0.070" thick)
- Billet rear servo for LBA valve bodies, heavier spring
- Solid (ridgid) front band, red lining (rather than flex band)
- Bronze thrust washer between output and input shafts (stock is a fiber material)
- A good quality pan gasket (rather than a cheap cork one)
- The rest of the sealing rings, rubber seals, gaskets are pretty much standard stuff
There are a couple other places that a teflon type ring is available such as the front servo, and the small rings on the input shaft.
Do you care-to-share where you get those individual parts from ?
