it would be in your best interest to pull the cover & axles and do an inspection as well as refill it with fresh fluid. Higher capacity covers are not that expensive and usually have fill/drain ports on them for easy servicing.
get yourself a lube locker gasket from Amazon for your application too.
I also like to put a few 1/2" round by 1/8" thick Neodymium Magnets inside the case to catch metal flakes and act as filters.
The Federal Government has not yet learned that you cannot legislate morality
1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23
1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55
1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91
1975 Duster 360 VS29L5 Daily Driver
