December 2015
The first picture here is the pile of bad metal that was removed from the car.
The lower cowl (rain pan) was blasted, primed, and painted body color to protect it from future corrosion and also so that you'd see body color if you ever looked down through the cowl vents.
Proceeding with fitting new metal.
