I've shortened many sets of manton rods. You won't get the end out. The way shorten them is put them in the lathe. Grind a cut off tools thickness to the amount you want to shorten them. Run the cut off into the rod just under the insert. The insert is hard so when you hit it, no big deal. Usually harder than the tool you'll use. So you wind up with the thickness of your cutter removed from the length of the rod, and the insert bare in that spot. Then heat a little and press the insert deeper into the rod.
manton reams that press fit, and you'll keep your rod straight this way. Thats a good way to do it. A clean square end and counterbore are key to the pushrod, and obviously not bending them trying to get an end out.
RIP Monte Smith
Your work is a reflection of yourself, autograph it with quality.
WD for Diamond Pistons,Sidewinder cylinder heads, Wiseco, K1 rods and cranks,BAM lifters, Morel lifters, Molnar Technologies, Harland Sharp, Pro Gear, Cometic, King Engine Bearings and many others.
