most gauge pods overlay the existing A pillar and attach with small plastic push pins. There's a plate where the clutch pedal linkage would go through the firewall so if you have an auto that's a handy spot. I have the Xmonitor gauge on my 01. module is under the dash and there is one wire going to the display mounted on the lower A pillar. Easy and non intrusive install.
