Here is a better picture showing the new shock plates. I made them with a D hole in the center of the spring for a tie down strap. When I go to the chassis dyno they need a tie down strap and I don't like it when they put a loop over the axle since it can crush the brake line. It was easy to just add an extra hole in the plate so now I'll have a strong place to hook the tie down straps.
