I don't believe you can get equal tq on all the bolts but if you were to drill out the nuts to a sleeve tight fit would help but I believe the sleeve should be hardened steel.I am going to use an ARP washer from a head bolt kit but it is only .118" .
GOTBOOST!New improved with Victor heads.
http://www.enginelabs.com/mopar-big-bloc...t-of-necessity/
