I will use spacers to raise the body 4" off the frame and then attach the frame to the rotisserie. Looks like he is wanting to leave the body on the frame. ...that will add a huge amount of dead weight that I would try to avoid. As in my original response. They have video of how to do this. There is a reason to leave the body attached to the frame. Got it mounted on the rotisserie with the spaces holding the body 5" above the frame. It is very well balanced this way and easy rotate. When I'm working on the frame only I will probably have to flip the mounting points to get a reasonable balance point.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
