The trickiest part for me was getting it off the frame and onto the rotisserie. The body mounts are easy to bolt to - even if you need to use a spacer.
I used an engine puller on the rear, while lifting the front of the body with my loader tractor.
Also, I had to fix the rear body mounts before I could use them to bolt to the rotisserie. Check yours!
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
