After about four years of body work and collecting parts finally installed driveline. As you can see from profile pic, Dart has changed colors. Driveline installed today and put the headers on the b1ba's. Custom made by my brother (68Shifter). 1 3/4 step to 1 7/8 SS with coating by QC out of Detroit. Yes, you can see a z-bar down there as well. RST clutch, red stripe proshifted 833, Action Machine Aluminum driveshaft, Strange S60, strange double adjustable in front, Viking DA's in rear, with strange lightweight discs all around
Motor will be soft for now as it is just Erson solid cam 360 at 11 to 1. It's a start I can build from though. Nice to put everything together that I have collected for so long. Fuel system is next, then wiring and finishing interior.
The Brodix heads have been a battle from the start, should have went another way but like with the stick, once stubborn, always stubborn. Head bolts, intake spacers, rocker stands, headers... gift that keeps giving
It is sure nice to clear up some room in garage. Hope to hear it this fall.
